Close-Hauling the Trades; some reflections upon the upwind sailing ability of Hunter Legends. Long Eastward passages in the tradewind belts can only be attempted by asailing vessel with superior upwind capability or by a very strong motorsailer(unless tried in an El Nino year with unusually weak trades). In fact, JimmyCornell's World Cruising Atlas states that the direct route from the NorthernQueensland coast to Vanuatu "should not even be considered". Also, he does not discuss any direct route from Vanuatu to Fiji. Instead, he advises sailors to exit the tradewind belt to the higher latitudes of New Caledonia or even NewZealand and hitch a ride on a passing low to make the necessary easting.Similarly, the advised return route from Hawaii to the N. American continentgoes North of the Pacific High through latitudes as high as 40 - 50 degrees N. Unfortunately, this time-honored strategy, which goes back all the way to theage of square-rigged sailing vessels with extremely poor upwind capabilities,comes at a significant cost. Time and again light sailing vessels venturing deepinto the belts of Variables (in both hemispheres) in search of a favorable windget blasted by the gale force winds, or worse, that tend to accompany thestrong Lows prowling these higher latitudes. As a "maverick blue-water Hunter skipper" I believe that light cruising vessels with strong upwind capabilities, such as the Legend 43, can be sailed most safely in the Pacific by abandoning the old "square rigger routes", which would have you make your Easting via the higher latitudes. Although these routes make perfect sense for heavy cruisers with traditional sailing rigs unable to run their easting down in the tradewind belts, it exposes all vessels to the frequent strong depressions spinning off from the Arctic and Antarctic regions. One only needs to read a few cruising stories to appreciate how frequently small yachts do get clobbered by gales in the Tasman Sea or in the higher N. Pacific latitudes. Besides, few if any sailors who want to sail back to San Diego from Hawaii really want to go "via Alaska" (as the traditional route around the Pacific High would have them do). In the South Pacific the story is the same for sailors who need to sail to Tonga, Tuamotus, Tahiti or the Marquesas from The Solomons, Vanuatu or Fiji. They typically end up riding the Lows of the higher latitudes unless, of course, they have a modern, upwind capable light cruiser such as the Hunter Legend 43...... Among the sailors we meet, even those who are sailing heavier boats withrelatively small, battenless mains will usually argue that their boat is "doinggreat" upwind. Yet, when pressed, they will admit that they rarely attempt tosail close-hauled against a fullblown tradewind. In order to understand thisreluctance to tack straight into the wind in strong (15 - 25 knot) trades, oneneeds to remember that for our size vessel (13 tons at 43 ft) it is necessary tokeep boat speed down to approximately 5 knots when sailing close-hauledagainst 6-12 ft swells in order to minimize bone-jarring slams. Naturally, the low boat speed amplifies the relative effect of drift. Secondly, we need to crack main and jib off by 5-10 degrees in order to avoid being stalled as the sails lose their optimum airfoil orientation when climbing and descending steep waves. Although handsteering, rather than using our trusty Autohelm windvane with accessory rudder, might enable us to point a little higher for a few hours,helmsman's fatigue will invariably give the upper hand to the tireless windvane. Under those conditions even our Legend 43, with its fully battened main andwell inboard sheeted staysail, rarely produces effective (i.e. over-the-ground)tacking angles better than 55-60 degrees. In other words, we sometimes haveto fight hard to maintain an average VMG of 3 knots over both tacks. Now,imagine replacing the fully battened and roached main with an in-mast furlingmain, the beamy hull with a more tender narrow hull and the deep ballasted finkeel with a shallower full keel while adding a 1 knot adverse ocean current...... Lo-and-behold, your VMG has suddenly gone to near-zero! In my experience, lowering the boat speed to reduce slamming in big oceanswells is often best achieved by pinching while remaining amply canvassed,rather than by further reducing sail. Close-hauled in 20 or 25 knot trades wetypically carry a well inboard sheeted staysail in combination with a single-ordouble-reefed main, respectively, because of the need to maintain sufficientdrive to punch through the waves. When you are pinching a bit and a big wave is starting to push the bow around the main will immediately power up and try to round the bow back up again. So, in effect, one ends up "jogging" against the swells at 5 knots, or so. At the higher end of the trade wind spectrum, e.g. around 30-35 knots, this approach merges seamlessly into modern, active storm tactics for light boats with good upwind capabilities. During the infamous 1999 Sidney-Hobart race a relatively light, 46 ft (?, I forgot the name and specs) yacht won the race (on corrected time) relatively unscathed by slowly jogging into the wind, while many bigger and heavier vessels that were made to bear off came to grief. Another example of the ability of modern, midsize yachts to safely head into strong ocean winds and waves, rather than running off at breakneck speed, is provided by Chay Blyth's "Wrong Way Around the World Rally" strategy. In short, with proper preparation and offshore enhancements a Hunter Legend43, or one of her close siblings, can become a perfect long-distance offshorecruiser for the tradewind belts, since she is able to sail both downwind andupwind with reasonable efficiency. In fact, our staysail-equipped Legend 43tends to sail better against strong trades than with them since we have a broad choice of upwind sailplans that balance quite well. During the N. Queensland to Vanuatu passage one of our crew members remarked that "our windvane had been steering quite well for the past several hours"; only to discover that the vane was accidently locked down and the boat had been steering itself...... By contrast, the B&R rig tends to make efficient downwind sailing a bit more complicated. As discussed previously on the HOW site, our most successful approach is to run DDW (plus or minus 20 degrees) with wing-on-wing jibs while using the double reefed, nearly centered main to reduce rolling (and double running backstays to keep the mast on board). Both close-hauled or near-DDW, however, Scanmar Marine's Autohelm windvane rarely has any trouble steering the boat quite well. In our experience, essential offshore enhancements include: (1) installation of an inner stay plus running backstays, thus backing up all critical mast stays while enabling the use of a furling staysail; (2) reinforcing all hatches and windows; (3) mounting dorade boxes in some hatch covers; (4) installing a windvane with accessory rudder; and (5) increasing diesel tankage to bring the range of the "iron genny" to approx. 1,000 NM. The latter modification really saved our bacon in May 1997, when we got caught in a strong El Nino weather pattern on our 2nd trip to Hawaii. Whenever the "loaded" question comes up whether "Hunters are bluewaterboats" or not, my standard answer tends to be threefold: (1) in the Tradewind belts a well-prepared Legend 43 can beat a conventional"blue water" cruiser with regard to average speed AND overall comfort on most any closed trajectory (i.e. with the tracks ending where they started; after all, isn't that the definition of a successful voyage?); (2) in the Variables a Hunter Legend can do fine but will have to pick itsweather windows more carefully than a conventional blue water boat (or usesome form of advanced satellite weather routing); and (3) in the higher latitudes we would probably not take our Legend 43 more than a few hundred miles offshore without major structural reinforcements. Alas, I also need to point out that the current generation of Legend and Passage models has moved further away from being readily modifiable for extended offshore passages. Although at boatshows my co-skipper still invariably picks a Hunter Legend or Passage model as "our next boat" (because she absolutely loves the spacey and cosy interiors) the absence of toerails and suitable seaberths, as well as the far too cramped anchor lockers, would make me think twice before undertaking another "offshore upgrade". Currently, therefore, we have little choice but to stay loyal to our beloved Rivendel II".Flying Dutchman"Nothing Goes to Weather Like a Hunter Legend"
