I am not sure if this should be in the 'sails call lounge' forum but it is related to maintenance of a home if not a boat.
I just noticed that a lumber yard in my NY area is carrying a line of Cetol products that are intended for use on the home (see link below).
I asked the 'paint guy' about this and he said that these products had been available for some time but they just started carrying them. I was tempted to pick up a quart but considered that they very well could have a different formulation then the Cetol intended for marine use.
I am planning on re-doing a finishing job on a nice wood entry way for an apartment building. The old poly is flaking and peeling as it gets a lot of sunlight and weather. My first thought was to go with the Cetol marine clear gloss that seems to hold up pretty well with limited maintenance.
Does anyone have any experience (good, bad, indifferent) with these new Cetol products? Is there any reason that using the marine grade Cetol for an exterior land based application does not make sense?
Thanks in advance to those of you who I know work with wood and finishes (Ross, Tony and others).
