Good news!! After having had a leaky boat for too long now, I have gotten a set of swing keel brackets made, they are installed, and now I sail with dry feet!! Swing keel brackets and the replacement thereof have been the topic on several bulletin boards and internet lists. I have received emails from folks interested in my having a set of brackets made for them based on the ones I got. The shop used my old brackets as a template for making the new set and are ready for a production run. The price per set, including shipping (in the continental US), will be $300. If we get several orders together, the machine shop will give us a discount, and the price will be $270. If you are interested in ordering a set or have any questions, please contact me directly by email at flyhop@comcast.net. My intent is to place the order by August 30th, so I'll need to know by then. All parts (save the brass plug) are constructed of solid 304 stainless steel (SS):* 2 Bracket Platforms @ 3/8" thickness* There is a retainer casting ("pipe") welded onto the platform which holds the pin. This was constructed out of a solid SS rod of 1.25" diameter and bored slightly larger than 5/8" inside diameter; this bore will allow easy installation of the 5/8" SS pin * Pipe is threaded on the inside and has provided an excellent seal for a brass plug* 12 SS bolts, washers and nuts* 5/8" SS pin* Brass plugAfter talking to some other owners, there seems to be some variation in hole locations for the brackets (holes are for bolts to hold bracket to the hull). Therefore, I had mine made without the holes being drilled. With the aid of a trusty assistant holding both brackets (with pin inserted) in place, I could mark the location of each hole with a Q-tip bent at a 90 degree angle and dipped in red fingernail polish. Then, I took them to the machine shop and had them drilled and countersunk (to the depth of the bolt head) for $20.
