Thanks again guys. I used to reef on the Capri 18, so it's not a big deal, just have to learn the details, which are different for the Mac. I will invest in the single line reefing system though...
As to the outboard, I understand the raising part using block and tacle, but how do you lock it down? Just hang over the transom and try to tighten the thumbscrew? I'm seriously considering investing in a new spring-loaded outboard mount. OR rigging something to update the existing one.
As to the mainsheet I think I have an idea of using a fiddle blog with a cleat set up and attaching it to a line running between two deck blocks of the original system. That way I could use the existing system like a dummy traveller and only need to invest in a fiddle block with clam cleat ($69) to make it quite workable mainsheet.
Also, the electric panel has been moved next to the keel winch, which explains a complete mess of wires all over the bilge. Haven't tried it yet, because I need to buy a new battery.
Finally, the boat came with a third sail - a very tiny jib-like affair that has a sleeve instead of hanks. and VERY short sheets. No idea what to make of it. Frankly, I don't think it belongs on Mac, unless I'm supposed to rig a second forstay.... Any ideas? The dimensions of that thing are about 9.5; 7.5; 14.5ft. Unless it's a weird trysail? but how would I use it???
