Bottom prep
Regarding the question on bottom paint & the keel, I will admit that we had the boat yard do the work; One of the four bolts holding the keel casting assembly had no head (previous owner?)so rather then chance a screw up, we decided to have the yard do the extraction & at the same time, drop the entire keel, inspect and replace parts as needed, and redo the finish on the keel itself before reinstalling. The keel was rough sanded, a "rustlok" primer applied and then Interlux bottomkote. The hull had been done by the previous owner. We'll see how it works by next July !!! I plan to pull her several times during the season to keep track of what's going on below !!
