Don Guillette
I thought my time on the Forum was up but the good folks at Sailboatownners.com decided to hold me over for a month due to the great sail trim dialog we had last month. Lets talk about BOOM VANGS. Boom vangs have been around for many years. The first ones were just a line attached to the end of the sail with the other end attached to the windward rail. Gaff rigged mainsails used them to prevent the mainsail from sagging to leeward. These days, boom vangs are used to control TWIST in the mainsail but sadly only about 50% of the cruisers and racers worldwide actually use this devise. If you are a middle of the pack to the back of the pack racer you should use this sail trim control as the guys ahead of you are certainly using it to beat you. If you are a cruiser, you should understand how this devise works as it will make your voyages a lot easier. Cruisers that attend my seminars sometimes preface their questions with the statement "I'm just a cruiser but --------". I always answer their question with the statement "there is no difference between cruising trim and racing trim. There is only a right way and a wrong way to trim your sails". Most sailors, be they racers or cruisers want to get as much speed from they boats that they are capable of giving. Dennis Conners once asked " How many times have you heard a sailor brag that last year it took him 4 hours to get to Catalina but this year he is happily and proudly doing it in 6 hours!". I will add that a well shaped mainsail can get you to your destination a lot quicker, will relieve pressure on your autopilot, give you a more balanced ride and prevent wear and tear to your mainsail. Now don't those benefits interest you? Hopefully, you have read my recent article on TWIST. You'll recall that as you move up the mast from deck level, the wind forces increase. In fact, the wind blows 60% harder at the top of a 45' mast than at deck level so some twist is necessary and sail makers automatically build it into the sail. To control twist in the mainsail, most sailors use only the mainsheet. That works but only to a certain extent. Sometimes they pull the traveler all the way up in an effort to control twist but they completely neglect that all important twist control, which is the BOOM VANG. Here is why the boom vang is so important. When the boat heads off on a reach or a run and the boom extends over the side of the boat, the mainsheet becomes almost useless as it can no longer exert a downward force on the boom and consequently the boom lifts up as the mainsheet is eased and MORE twist is blown into the top of the sail. Experiment with this the next time your on the water and see what happens. Sailors try to correct the situation by trimming the mainsheet in an effort to correct the twist problem at the top of the sail and completely neglecting the device (boom vang) that was designed to easily correct the situation as it exerts a downward pull directly to the boom. The result of only using the mainsheet is that the lower portion of the mainsail, which is obviously the largest part of the sail, become a trimming mess, which results in a excessively heeled over boat with a lot of weather helm. If any of this sounds like a situation you encounter on your boat, try this simple solution. Grab the boom vang line and CRANK ON IT. Experiment with it and like the old song says "take it to the limit". Pull the boom vang completely tight and then ease it all the way and watch what happens to your mainsail as you do so. Once you see how it works you'll use it all the time. Any questions or comments?
