It might be a real problem..
So many blister ON the surface , usually mean many of them UNDER the gelcoat , still in the forming proccess which will show up next season.. Usually this Osmosys proccess- or actually Hydrolysis - will in time cover large part of , or all of the hull . Local treatment will be good , but for limited time .Professional total treatment might cost several K dollars for a 30 footer!!.Be aware that many 'middle of the road' production boats of the eighties , might develop at 10+ years of age Osmosys , less so-or just later..- ones that were :1.professional epoxied from ANEW , and 2. had the boat out of the water yearly for at least several weeks. Hopefully the newer gelcoats and newer resins-venylesther, etc. might help. But what will REALLY matter- according now to top professionals - is better laminating proccess WITHOUT VOIDS of the fiberglass layers; more man/hour work per square/feet of laminate , professional work and/or modern laminating procedures (vacum,forced-feed ) in cleaner and dryer enviroment and chimicals of high grade purity . All this can explain why some boats don't get Osmosys , even after 15 years , but some do after 5-6 years. Frankly , only real 'bad boats' do get Osmosys before 5-6 years , so most buiders giving a 5 years warrantyon the hulls ,has little meaning , except that the laminates are of basic acceptable quality ...Look for the ones that give unconditioned warranty for 10 yearsagainst blistering if you espect high quality..
