Got it goin
Thanks for the tips everybody. My problem was that I was bleeding the engine incorrectly. I was bleeding the engine at the nut above the filter and the nuts at the injectors themselves--on the top of the engine, directly above each injector. A friend who worked on diesels showed me this and it has worked every other time I needed to bleed. This time, I talked to a Yanmar mechanic on the phone, and went over to his shop where he showed me how to properly bleed an engine. (For all the people in the S.F. Bay area, List Marine in Sausalito--great people, although extremely intolerant of dissenting opinions) He said don't use the starter; use the manual fuel pump--the small lever attached to the fuel pump on the engine. This lever provides 7 or 8 pounds of pressure to the fuel line. So you push the lever a bunch of times, crack the nut on the fuel filter, push the lever some more, get fuel to spurt out, and shut it while you're pumping the lever. Then--this was my problem--I missed the second bleed point, which is on the fuel injection pump, not at the injectors themselves. I had an air bubble in there, but once I cracked that nut, and pushed the lever a few times, fuel spurted, shut the nut, I was good to go. He said not to even bother bleeding at the two injectors themselves. After that, I was out for the day sailing, me, my cousin, and some ten-foot swells. Thanks again for all the help.Josh
