Don't use bleach
Bleach is the most over-used, over-rated product used on boats...it doesn't do half of what people think it will. Since I don't know what "green stuff" you're using in the tank, I can't tell you how it will react with bleach (if it hasn't killed you yet, I doubt if it will)...but bleach degrades rubber and neoprene, only kills most of the bacteria that cause odor, and doesn't clean anything. Since it's our own product, I naturally recommend "C.P. Cleans Potties!" (it's in the online store here)...which is bio-enzymatic cleaner that actually does clean out the animal fats etc that make a toilet and tank "dirty"...kills odor on contact, and is a d'd fine product!
But if you don't want to use that, you'd be better served just putting some detergent and water through it than bleach.
