Hello All,
I'm a recent owner of a 1984 First 30E, and I have a couple of things I could get some help with:
When we filled up the fresh water tank (port side, below the settee in the cabin), it looked like water overflowed into the bilge. The water tank does not appear to continue to leak, because the water level gauge has remained stable since, and there is no new water collecting. And later, when I was trying to pump out the bilge, it seems like the manual bilge pump is not doing its job.
Any guidance would be much appreciated.
Thanks
shyam
- First question is, where is the water tank overflow supposed to be on these boats?
- Second, what make and model of bilge pump is in use in these boats? I took a quick look under the pump and there are no obvious marks, nor leaks ...
Thanks
shyam
