Hi all,
I recently bought a 2005 Beneteau 343 and am excited to have found this community. I am going through the house and starting battery system and need to replace all batteries (mine only came with 1x house battery) with new.
Option 1: buy 2 of these for house bank, gets me 210 amp hours
https://www.westmarine.com/buy/west...-105-amp-hours-group-31--15020332?recordNum=3
Option 2: buy 2 of these for house bank, gets me 230 amp hours
https://www.westmarine.com/buy/west...ine-battery-230-amp-hours-group-gc2--15020340
The advantage of Option 2 is I would get more amp hours out of the 2x 6v wired in series. And according to MaineSail, the 6v bank will yield much longer life due to superior construction of the batteries. Price comes out the same. The only question is if we have the height under the berth to fit, because the 6v are slightly taller. I'd be curious if anyone with a 343 has fit the extra height of the 6v without issue
https://marinehowto.com/what-is-a-deep-cycle-battery/
As I have reviewed the wiring diagrams, I am confused about how Beneteau has wired the house and starting batteries together. Specifically, I cannot understand the operation of the "parallel switch" connecting house and starting positive battery switches (indicated with a blue wire in the attached). My understanding is that this switch (label says Albright SW80-68) will parallel the starting and house batteries, but I cannot identify under what circumstances. Is it automatic whenever both positive switches are on? Or manually activated? "General 12v Schematic" below matches the configuration currently on my boat:
I don't believe my configuration matches MaineSail's diagram below, because the jumper parallel between my house and starting positive batt switches runs through the Albright Parallel switch, which is not shown in this diagram.
Thanks! Ted
Thanks! Ted
