I have a 2005 B32 which has the Calira Panel 201. The sender unit screws into the top of the water tank. There are 5 probes of different lengths -- one is ground and the other 4 represent the tank level as 1/4, 1/2, 3/4 and full. The simple first check is to clean the probes and short one to the ground probe (one of the 2 longest) with an alligator jumper clip. If that doesn't register, you could move the sender connector to the second tank sensor input. (The electric panel has a momentary rocker switch to display the level in 2 water tanks but I have only one tank installed.) The connector has a 5-pin ribbon cable and the two receptacles are side by side behind the panel. When I had a similar problem it turned out to be the connector itself -- I used a pair of pliars to gently squeeze the connector to help it bite into the ribbon cable.
Good luck!
