Bathroom faucet -2000 H380
viper
Jul 31, 2016
131
Hunter 380 Cape Coral, Fl
Hot water side is slowly coming out.. Cold water is fine ,all other hot water outlets fine on boat...
What do I need... new valve, new faucet?
Regards,
Viper
Nov 6, 2006
9,885
Disassemble and clean it out.. There will be scale in the piping just below the valve some of which will have partially clogged the valve ports. My hot sink faucet does this about every 5-6 years.
Jun 4, 2004
255
Hunter 376 Annapolis MD
Or it could be what happened to my H376 hot faucet. It is a very odd design. The stem is in two parts that are screwed together. If they start unscrewing, they will cause the symptoms you describe. If so, you need to take the stem out and screw it back together. You'll need some trial and error to get it to the right length.
allan
viper
Jul 31, 2016
131
Thanks for your comments (both of you)... The water at Brunswick Landing is very hard....
I will play plumber tomorrow.
Regards
Likes: kloudie1
Dec 19, 2006
5,809
Hunter 36 Punta Gorda
I had slow hot water and took a part hosing going into hot water heater screens clogged and took a part and much better but try also as above.
Nick
Dec 19, 2006
5,809
I did install single lever in bathroom from HD because handles were striped.
Nick
Hunter 340 Baytown TX
It may get me kicked off the site, but I found an exact replacement for the head sink faucet for my 2000 Hunter 340 for $20 at an RV parts website when Hunterowners said they were out of stock on it. And a chrome showerhead and hose to go with it.
