replaced winch
If you have the original winch on your trailer then it probably *is* undersized for the job. A couple years ago as I was bringing our H26 out of the water, several of the teeth on sprocket on our winch broke off. I had the brake on, but when the teeth broke, it made the brake useless, the arm swung back and shattered my wrist. At least now I don't need a barometer to tell when the weather will change. I put a post up here telling about it and suggesting everyone upgrade their winch. I forget the company who supplied the winch for our Hunter trailer, but they gladly sent me the largest winch they made. I think it's rated to 3500 lbs. I highly suggest changing. It was just a matter of undoing four bolts, changing the winch, and redoing the four bolts. I used a new strap, as I prefer it to the cable. Good luck.
