Anchor light change to LED
Jun 24, 2014
45
Beneteau 461 Kent Narrows, MD
Hi there, I changed all my navigation and interior light bulbs to LED. Except for the anchor light. I believe it is an 360 degree Festoon bulb.
but I don't know the size 37 or 42mm ?
Any advice is very much appreciated.
Thank you
Peter & Lorraine on Belvedere
Oceanis 461
Wells Cove Marina
Kent Narrows, MD
484-437-3262
Ron M
Mar 21, 2010
67
Beneteau 331 Rock Hall, MD
Anchor Light LED
I changed my anchor light to LED a couple of years ago. Mine is an Aqua Signal Series 25 which uses a 41mm festoon bulb. Since yours is a bigger boat it may have a larger version. I used a Dr. LED #9000241. It is a 39mm bulb, but has adapters to make it a 44mm. Works very nicely.
Oct 6, 2010
119
Beneteau Oceanus 321 Carters Pt.
Recent aeticle in Sail Mag re merrits of chainging the bulb or replacing the fixture on navigation lights.We replaced the whole fixture for our anchor light 3 years ago,still uses the original two wires but is automatic (dusk to dawn) manual on/off,pulsating and a few other options works great.Will see if I have manufacturer name when I am on the boat in PM preping for upcoming hurricane this weekend
Jun 24, 2014
45
I stay corrected ! Went up the mast only to find out it is NOT a Festoon bulb.
It is a 43mm Barrel bulb. Now I have to find out if I can return the Festoon for an exchange...
Cheers
Peter
Thank you
Oceanis 461
Wells Cove Marina
Kent Narrows, MD
484-437-3262
