Greetings everyone!I thought I had a sunfish... the sail is definately sunfish like, as is the size (13'10") the dagger board, the rudder, etc., are all sunfish like. However, this boat has a teak wood coaming... it has a no lip around the cockpit (to anchor main sheet block), but otherwise, it looks very much like a sunfish.SO ... the original owners say it was an "AMF" boat. In 1976, when AMF was making Sunfish, did they ALSO make variants that were SIMILAR to the sunfish (same sail rigging, etc.) but that were, well, different????Most important question: Will Sunfish replacement parts (lines, rudder, etc.) work for this one? I can produce a picture if necessary [where would I put that?]thanks!!!!!!!!!!!!john.
