G
Greg
I covered my 260 with a blue poly tarp for the winter, which worked well except for one problem. The aluminum grommets in two places rubbed against the hull, leaving aluminum stains. There are no scratches perceptible when you run your hand across the surface, just unsightly gray marks.How do I remove aluminum from fiberglass? Any recommendations?Thanks much--Greg
