Venturi info
I too have installed a venturi unit (Mermaid condensator kit). Works very well, but... I offer the following cautions/suggestions:I believe John K. is correct in his statement that a clog in the discharge line is very unlikely, and if it was to occur the unit would quickly develop high head pressure and shut down. The condensator does have a very small pick-up tube which does have a one-way valve (which categorically you never want to trust) so in the unlikely event the discharge is plugged the pressure produced by the pump wouldn't force water back into the pan. I don't believe that this is the typical concern with the device however. I believe the concern is that many boaters fail to regularly check the filter, which is placed before the venturi device. If this line or the venturi port itself becomes obstructed the device fails to empty the pan and the overflowing pan causes the damage. In very humid climates were units are sometimes left running and unattended for days or weeks in the 'de-humidify' or cool modes this can amount to a large quantity of water (gallons per day)! I have 'heard' third hand that some boats were damaged in this fashion.If you install the pick-up using 1/4" tubing (greatly reduces the 'sucking/gurgling' sound) through an easily checked, easily cleaned filter, you are part of the way. I fashioned a stand tube mount for the pick-up so that the small 1/4" line enters the pan vertically (angle cut the hose end), instead of utilizing the existing pan drain holes. This does two things for me. First, it keeps the pan virtually dry instead of waiting for the water to reach the level of the drain holes before it's picked up. Second, it allows me to run a tee'd conventional drain line from the pan to my shower sump, just in case the condensator fails or some water is left behind when the boat is underway. I installed two fittings, one on port and one on starboard connected with a tee. Any left over condensation would just drain into the line and not slosh around in the pan. I have monitored the water in my pan, and would bet that no more than 1/4 cup has ever been in the pan, if that. I have never found any water in the shower sump from my overflow lines.Last, IMHO you shouldn't leave an AC unit on unattended. After all, if the discharge line was plugged on a 'conventional' drain system, who's to say the hose clamps, discharge thru-hull, etc. might not pop off and have a 'negative impact' on the vessels buoyancy? Jeff JonesEscapade
