I have a knock coming from my number one cylinder on my 3GM30F. I know it's coming from number one, because when I open each of the compression releases, the knock quits when I open #1. From what I can tell, the knock is evident at idle, and appears to get better (reduce in intensity) at higher RPMs. It's a sharp, clear knock, and not a dull thud. There's no unusual smoke coming from the exhaust. Based on what I've read, I think I'm dealing with a late or sticky injector that's spraying late and giving me an ignition knock. I know that you can also get knocks from the connecting rod bearing, piston pin, or crank bearing. I'd naturally prefer that it be coming from a late injector. How do I tell for sure?
