Adding Battery
My Yamaha came from it previous owner with two batteries.The first is a smaller battery, and it is under the forward seat, by the table, on the starboard side. There should be a small shelf there. The second battery is up in the front of the v-berth. Beyond the engine compartment. Look under the front cushion in the v-berth and there is storeage area. I use tie downs to secure both batteries. Do you have a battery selector switch on your boat. It should be in the same area as the seat with the smaller battery. The fiberglass seat has a molded in section to accomdate the selector switch George
