Hello Everyone!
Excited to join the community - I've done a good amount of reading through posts before/ after recently purchasing my '84 Mac 25, some good advice on this site.
I bought the boat about 1 week ago for $1900 in the water. I've taken it out a few times and loved the feel of it when sailing, boat really has spirit.
I'm now wondering should I,
A: Just sail the heck out of this thing and sell it in 6 months while trying not to put a dime into it?
B: Get a marine survey, see if the hull is worth saving, and get sanding if it is?
Topside and Cabin
Bottom (photos provided by seller)
The Good
To me, this could be the perfect boat for cruising around SF bay with the occasional overnight or weekend trip. The fact that it doesn't have a real head or galley are positives for now, since those would just be more things to pay to fix/ maintain.
Looking forward to hearing whatever you guys have to say - this is a long post I know so even if you just respond to one question, or give an opinion on the bottom, that would be much appreciated!
Thank you!
Topside and Cabin
The Good
- 2011 Nissan 6hp outboard motor starts up second pull, solid so far
- Cabin is clean and dry, hasn't been gutted or overly modified
- Cushions have been reupholstered relatively recently and are in decent shape
- Keel pivot bolt looks new, the locking bolt has some corrosion at the bolt but the washer looks like OK (needs out of water inspection)
- Main and jib sails are in decent useable condition, but are still the originals
- Pop top works, supports were with the boat
- Generally clean, no mildew smell, no spider webs
- Topside fiberglass staining appears reversible with enough elbow grease
- Topside feels solid, no softs spots found so far
- Running rigging needs TLC - Jib sheets need replacing, main block is original and needs replacing, halyards need replacing soon
- Standing rigging is original and has rust and kinks, stays and shrouds should be replaced (have already been looking at BWYachts.com)
- Mast base support (tabernacle?) appears bent/ misshapen and needs to be replaced (I plan to reinforce this area as well per things I've read on here)
- Some cracks in topside fiberglass around a couple stanchions, and random spots, need to make sure no water intrusion and repair asap
- No battery currently, basically planning on rerunning all the electrical wiring and replacing the running lights
- Wood trim on hatchway needs to be replaced as its completely sun worn and split, tiller needs a deep refinish as well
- The fiberglass on the hull. I'm a little worried about the pitting and blistering you can see in the photos, particularly IMG_2891 where you can see big chips
- The keel - I'm hoping all is good as far as the connection point, but if I wanted to keep this boat long term, I need to consider the sandblast/ recoat process
- Bottom paint - Not even sure what's really going on with the bottom here, it will definitely be a workout for me tackle solo though
- Any advice on options A or B above?
- Would I be better off taking the 5K+ this restoration could cost and buying something that needs less work?
- Can you tell from the photos if the hull can be brought back to glory? (for a reasonable expense of time and money)
- Does it look like this boat even had bottom paint? Has it all worn off or something? Almost looks like just fiberglass/ gel coat
- Is it worth getting a marine survey to determine if she is seaworthy? Or is that not the right course of action?
- Am I crazy for buying this boat? Think $1900 was a good deal?
Thank you!
