5200 Trick
  • Thread starter Justin - O'day Owner's Web
  • Start date
Here's a good way to remove items 5200'd to your boat: go to your local discount store and buy a cheap set of guitar strings. Use one of the heavier strings, the type wrapped with copperwire around the outside. Take two small dowels and make a saw by winding each end of the string around one. Then use the saw to cut under the object adhered to the deck. I have used this method with very good success. Justin - O'day Owner's Web
