spreaders and shafts
Thank you all for your helpful comments. John, regarding mast and spreaders: I've had the mast out several times over the past 6 years, as I've been unstepping the mast for winter storage (except for this year). I re-tune the rigging myself, generally using the procedures recommended by Hunter in its "operating manual" for this boat, which I was fortunately able to get from Hunter some years back. With the mast stepped and with no tension on the shrouds or stays (i.e., just with slack taken up), and with the main chainplate visually lined up with the base of the mast, if you were to look upward you would see that the spreader tips are canted a few inches forward. So it's doesn't appear to be rig tension that's the problem. Without any tension, the spreaders definitely cant forward. I, too, thought that the spreader fittings might have been installed backwards, and tried switching them. But the holes don't line up when port and aft spreader mounts are switched. And I they can't be just flopped upside down, since the spreader mounts have a slight upward cant to them, and flopping them upside down would make the spreaders point downwards. In general, when I tune the rig Itune it with less aft rake to the mast than one commonly sees on boats, but the 37c mast cross section is pretty hefty, and I never felt comfortable pulling the tip of the mast too far aft. But if I did, then the spreader tips would better line up with the mast as sighted from the side. Maybe I'll try this during the upcoming season. In spite of all of this, the good news is that the boat performs well on all points of sail -- at least by my cruising standards. The spreaders just look strange -- sort of like the tail on a Mooney if you're used to looking at Cessnas. I might try giving Hunter a call -- maybe a few of the folks who assembled these boats in the 79 time frame are still around. Thanks again for the info.
