30 Hunter vibration
Jay
I have a 1981 30ft Hunter with a 2 GM Yanmar diesel engine. At 2000 rpm's I get a loud knocking. It sounds like someone is under the boat knocking on the hull. This past spring the cutless bearing was replaced and the knock remained. Any suggestions?
Michael Cohn
ouch
Have the cutlass bearing inspected again, also check motor mounts and alignment. MC
Rich McCue
Same noise
I had the same noise ,when I started the boat or under way.Check shaft alinement and make sure mounts are not grounding out.I took a rag around the shaft and moved the shaft untill the noise went away.
Jay
Same noise & Ouch
Thanks for the confirmation. These were the next things to check this winter. Jay
Paul Harmina
Big ouch
Don't ignore this problem. I did, and now I have to replace the shaft, strut cutlas bearing, and get everything aligned. What could have been taken care of without a lot of expense is now costing in the thousdand. Hopefully I will now be able to motor a little faster without all that vibration.
