Today I found more than "usual" oil in the engine bilge after a long, for me, two hour engine run. It seems the engine below the flywheel is coated with oil. The dip-stick showed low but not at the bottom and seemed normal. Has anyone experienced an oil pan gasket leak or other oil leak related problem? Thanks in advance.
