24 or 26 Hunter
2
- - Edmonton Alberta Canada
I am going to purchase one or the other and will be sailing mostly myself what do you think is the 26 to much if the weather turns?
Bigger is better in this size range
Many of us single hand much larger boats, mine's a 34. Go for it.
May 31, 2004
858
Catalina 28 Branford
Nice to have the extra weight
If the weather gets nasty, its nice to have the larger boat's extra weight and stabiity. The 24 is easier to trailer, but if that's not a concern and money isn't a factor, definitely go for the larger boat. Assuming self-tailing winches and roller furling on both boats, I doubt you will find much difference in ease of singlehanding (especially after your first few trips) between the two.
F
Fred
90 per cent of the time you're on the boat
you are at anchor or at a dock. You will appreciate the extra space and headroom of the bigger boat. I don't think you would notice the difference in handling between the 24 and 26, except the bigger boat will be more comfortable underweigh as well. Be sure to get an autopilot if you're single handing. The tiller pilots work fine. If you get a boat with a wheel, it's more expensive nd complicated, but still well worth it. You will be more likely to get crew with the bigger boat (this may be a disadvantage, as it can lead to matrimonial entanglement), and when you invite a fellow sailor or two to the boat for a beer, the 26 interior and cockpit are both great for entertaining.
G
George
Singlhanding small boats
I agree either the 24 or 26 is easy to singlehand. This task is made much easier if you have roller furler and spinlocks. See the link below for more information on this subject: http://kobernus.com/hunter260/spinlock/spinlock.html
Feb 4, 2007
2
I will charge my wife 20.00 per day for the extra
Thanks for the responce ,I am having a hard time finding one fitted with wheel controls but I can see the advantages.How do you protect the water balast from bringing mussels that are not needed in the north.I stay in Alabama in the winter and Alberta in the summer.
F
Fred
On a boat that size a tiller may be better
You can lift it up so it's out of the cockpit, and the autopilot costs a third of the wheel pilot. On a water ballast boat the feel you get from the tiller may tell you when to reef so you don't get overpowered. Mostly the advantage is a wide open cockpit.
Rob Ullinger
Zebra muscles on Lake Erie
When we bought our H23.5 to sail both on Lake Erie and Ohio's inland lakes, I called the Ohio Sea Grant project. They recommended a couple ounces of household chlorine bleach in the ballast tank. Fair Winds, Rob S/V Kinship
Feb 9, 2007
1
- - Panama City Beach, FL
Take a look at the Hunter 25
The Hunter 25 is also a great boat. Not sure there any on the used market yet but most dealers should have the boa tin stock. We have had nothing but positive feedback from our customers! Thanks, Brad Stephens www.sunjammers.com Authorized Hobie/Vanguard/Hunter Dealer brad@sunjammers.com 850-235-2281 866-sun-jamm Panama City Beach, FL Online Store Now Open!
