So........I'll start by assuming the "Keel Trunk" is the two small teak panel cover areas in the floor of the Cabin.
If I am correct, the attached drawing from the Owner's Manual shows the sink drain tube dumping into this area.
So every time you use the sink, you need to pump out this keel trunk?
Why have a sink
Why have a sink
