Sleeves inside the drain openings at the aft transom causing leaks in the interior.
Is there a part that can replace these sleeves, possibly a threaded device that can be inserted into the hole leaving the sleeve and thu tightening up the interior and exterior surface of the transom to alleviate these leaks?
