Good afternoon all. The last couple of weeks I've come up with two solutions for securing the battery, both of which used a bar across the top of the battery. The first used two SS screws through a pocket hole and because of the tight space I kept stripping the screw heads. The second method, which I like better uses opposing SS spring-tensioned barrel bolts. In both cases I used a refrigerator gasket along the bottom edge to create a tight seal. Steve
