Correct placement of cradle pads on 27-2 (89-94)
Jun 22, 2025
1
Beneteau 235 Kingston
I need to modify a cradle to hold my Hunter 27-2 (89-94).
i do not know where the bulkheads/strong points are located on the hull so not sure where the cradle pads
should located. Any info re cradle measurements for a 27-2 (89-94) would be greatly appreciated.
(dmaingot@hotmail.com)
Sep 27, 2020
13
Tartan, Compac T27, CP19 Stuart
Pick reference point and measure to the structural bulkheads inside.
IE. Measure from the transom to the first transverse bulk head. Often this associated with the cockpit lockers. Next there is usually a bulkhead around the engine bay associated with the bridge deck. Next front wall of salon. Often there is a full transverse under the v berth.
Aug 10, 2020
544
Catalina C25 3559 Rocky Mount
Mine has marks for slings for hauling out. I would guess they would be in about the right spot for a cradle as well. If yours is lacking these marks, I will take pictures and show you the location
-na -NA Anywhere USA
@SailingLoto
Those strap marks were installed by Hunter. Please take pictures and measurements and post them here. In addition can you please post this information under Hunter boat information. Thank you.
@ColdSophie
If you do get a photo and measurements please advise. If not, call Al at the forum parts forum and he can advise. They have a copy off your build list of parts and are former Hunter employees. They do their best effort to help you
