Had a different failure first... Mainsheet traveller block snapped in heavy winds during a small jibe and the boom went flying starboard and smacked the lower shroud and broke the U-Bolt. It was clearly corroded to begin with, and I know I should check them all.
My question though: Does anyone know off the top of their heads what size and make these are? Or a specific model number?
I found the upgrade kit on CD, which I don't need because I already have the originals as per 1987 Catalina Yachts, and the very friendly Warren in tech support couldn't tell me for sure what the make/model/size is but is guessing it was a Gerhauer part.
I also found this on CD, but not sure if it's the exact same one either. I will call CD and see if they know, but if not, I'll have to go measure mine. I'm trying to order one to replace this one before I pull it out.
Lower Shroud Chainplate Upgrade C-30
Catalina Direct, publishers of the Catalina 22 and Catalina 25 Owner's Handbooks and the largest supplier of parts and Lewmar winches for Catalina Yachts in the country
www.catalinadirect.com
Deck Tie-Down U-Bolt Kit C-34, C-36, C-38; Chainplate U-Bolt Replacement Kit C-30 '84->
