This is better than an anchor thread, I need more popcorn
@Scott T-Bird tension and stress are NOT the same. Tension is measured in pounds-force, stress is in psi. Stress is equal to tension divided by cross section area of the shroud.
Yes, I have that wrong. I believe I am thinking in terms of tensile strength, measured in English units, psi, which is basically stress. My basic point is that we are essentially discussing the static adjustment of tension in the shroud rigging to best maintain the mast in-column under the variable dynamic loads dictated by sail area, wind speed (& shear) and boat movement thru various states of water condition. In my mind, it is easy to lose track of the conversation (but maybe that is just me!)
@LeeandRick posted an interesting reference but I have to admit that I was only able to absorb the 1st page. Beyond that, I was lost. But the part that I was most interested in learning seemed to be stated in the very first paragraph. "
The outermost stays (V1, V2, D3 in Figure 1) usually carry the highest loads, and as a group are termed the cap shrouds. They work in conjunction with the spreaders to provide lateral support to the mast and transmit most of the forces from the sails to the hull. The diagonals often carry smaller loads as they support the middle regions of the mast, helping to carry the lateral load." (The figure portrays lower stays as diagonals). This was not intuitive to me and I was happy to see this defined. Good source, I think,
@LeeandRick ! On my own boat, the diagonals have a smaller wire diameter than the cap shrouds. But then, I do have forward and aft lowers - a pair of lower shrouds (thus a larger combined cross-sectional area?) opposed to the single wire of the cap shroud.
I'll readily admit that the conversation can easily transmit misleading information. But that is what conversation is for. If everybody were an expert and the conversation has no controversy, how boring would that be in a forum? Who would ever learn anything in an informal setting if knowledgeable minds adopted a condescending attitude toward anybody whom is striving to contribute to the conversation? There would be no purpose to this forum, don't you think? I'm sure there are academic forums where know-it-alls can hang together!
