No, it is not wired correctly. The windlass load is going through the C-Series breaker and it CANNOT pass through this type of breaker!! It needs to go through an ON/OFF siwtch then a 285 Series or similar breaker. The house battery needs a fuse regardless of the windlass stuff. You don't want to know what happens if a wire shorts between the battery and the 100A breaker. The house bank fuse is an ABYC requirement for safety.Here is the electrical diagram for the new and installed Lewmar V2 windlass. Everything is wired according to the diagram (Contactor setup), with the exception of the battery isolator. The windlass is currently wired: Windlass>Bus>isolator switch>100amp breaker>battery + terminal.
If the wiring between the Blue Sea 8080 panel and the battery is not sufficiently sized for the windlass then the windlass wiring would start all the way back at the battery at the house bank fuse.
This is what correct wiring would look like.
