During a fairly large regatta a few years ago, I was out in a mark boat. Actually, I was out in one of the more lowly mark boats. It was a sporty day & after getting the first race off, we went AP over A fairly soon, because conditions out there in the open ocean were building quickly. As soon as we saw the flags, we yanked our marks & started to deflate them. By now, seas were 6-7 & fairly close. We then got a radio call from one of the higher ups. He had “more important” things to do & didn’t have time to pull his marks, so he wanted us to pull his for him. We complied & ran over to his course as quickly as was possible in the conditions, which were now getting to be more like 8’. We approached the first mark from downwind, as we normally do, not knowing that the mark had about 15’ of line dangling behind it. Of course, as we got the mark to midship, that line found our prop.
So here we are, in seas that are 8’ & building, with winds blowing well in excess of 20 knots, with gusts well over 30, with a prop that is fouled on a line that is connected to a well set anchor. Less than 10 seconds later, we were stern to & taking a beating.
We had some pretty hearty guys on board that were generally quick to want to prove what they could do in any situation, but this time, the call went out for the guy with the longest arms to try to reach for the line that was around the prop & either untangle it or cut it loose. Well, I was the tallest, so everyone looked at me. I knew that my free ride was over.
Next thing you know, I’ve got a bowline on a bight for a safety line around my midsection & shoulders, and I’ve got one foot on the skeg with the other on the transom D-ring, as I’m working that line off of the prop. It was wound tightly, so cutting it would not have solved the problem. I needed to unjam the prop so that the motor could start. I was using a boat hook & a screw driver for pry bars. The waves gave me a pretty good pounding. I tore open my favorite pair of offshore bibs. I lost one boot. I got a couple of nasty looking bruises & lost a small amount of blood. But I did eventually get that line out of that prop.
Meanwhile, the guys on deck that were not actively busy keeping me from getting washed away, were working a 5 gallon bucket as fast as they could, in an attempt to bail water out of the boat as fast as it was coming over the transom. When I got yanked back on board, we got the motor started (thank god) & rode the back side of a wave for a few minutes to clear the deck of excess water. The boat felt like a boat again.
We then went back for the marks. We hit the first one from the side, pulled in the excess lines, worked up to where the anchor was set, tied off to a Sampson post & powered the anchor out. It came up twisted, but it came up. We did a repeat on the other mark, got everything on board & headed for the barn.
We were the last ones off the water that day. Nobody asked us why. We didn’t volunteer any unnecessary info. We quietly found a place where we could straighten the bent anchor, using a trailer hitch as a press arm. The next day was beautiful & the races resumed. The racers were not the only guys that got a workout during that regatta.
