So I ran aground and scraped up the bottom of the fin keel, decent 1/2"+ gouge in there. There don't seem to be any hairline cracks or other damage where the keel meets the hull. It's on the hard right now, two wooden blocks under the keel with jack stands on the sides. I researched a bit on how others have worked on the same issue - filing down the lead, filling with special epoxy where necessary, then sanding and putting on a couple layers of bottom paint.
So I can get to part of the damage right now, but the main gouge is sitting right underneath one of the wooden blocks. Boat is packed right into the yard for winter storage. Do I have any hope of the yard guys being able to take some of the 13 tons off of the block so they can move it slightly for me? Any idea how they would they go about doing that?
