Hello all,
So I have a 3000w inverter that I just started to use as I am now working from the boat..... printer and charging lap top. I never used the inverter before however it always hums loud from behind the electrical panel. Inverter works fine. So today I opened up the panel and there is a relay prior to the ac panel that is making all the noise. I looked it up and only $35. Just want advise if this is what happens when a relay starts to go bad or is it sign of something else?
Thanks!
Greg
Thanks!
Greg
