I have a cartridge fuse connection that when the fuse is twisted the connection will disconnect then reconnect if twisted a bit more. I have tried several fuses, including new Blue Sea fuses, but the issue persists. I also have tried filing the brass(?) connections. Any suggestions to fix this issue?
