I’ve not installed a CO monitor in either of the two cruising yachts we’ve owned. My surveyor of late has strongly recommended installing one or more now on the Bavaria. The Diesel engine exhaust system runs under the bunk of the port-side quarter berth overlain by a loose access board; the berth being enclosed (i.e., cabin). That’s where the water muffler resides. Plus, we have ducted heating from an Espar diesel-fired heater, the exhaust for which is high topsides at the starboard transom, a couple of feet above the Diesel engine exhaust. So, to alert early while sleeping in the quarter berth with the Espar running, where is a CO monitor best placed to detect incoming CO? High inside the cabin, low inside the cabin, or elsewhere outside the cabin? Also, assuming some diesel exhaust can escape the water muffler (which is rusting) and enter the cabin via the access while running on diesel power, same question. Opinions?
