Burglar proof your Hunter 49 companionway hatch for $5
1,837
Hunter 49 toronto
We are storing our 49 this year in a yard which doesn’t have electric gates or full time security. While I am concerned about the potential for break-in, it’s not keeping me up at night. Still, you have to appreciate that the companionway doors on the 49, (and other Hunters), would easily be compromised with one swift kick. Frankly, not too many companionways are secure, in that you can either snap off a padlock, or easily jimmy them open.
Having seen several other boat owners who posted security enhancements, I didn’t like any of them. They either entailed making custom metal work, drilling holes in the boat, or having something that looked like a prison gate.
What I wanted was something that was :
Very cheap
Sturdy
Gave the message immediately that this wasn’t going to be easy, and to “pick another boat”
Could be taken cruising with us, (using no space), in case we ended up leaving the boat in a dodgy marina.
The implementation (below) would take about an hour, (tops) to make, and can be modified for different Hunter models which also have swinging companionway doors, and sliding hatch.
The simplicity of the pictures speak for themselves. The 2x4 is trimmed to have a very close fit between the hatch teak strip, and the forward fiberglass hutch. The lock is a simply bicycle lock. The only critical thing is lining up the lock holes with the grab rail handle. As well, you need to cut the bottom corner of the wood so it doesn’t interfere with the side of the hatch slide rail.
The forward aluminum right angle bracket can be just about anything. Don't go with steel as it will rust. It just needs to hook under the handrail, and keep the wood from being pried sideways.
The aft teak strip is screwed to the hatch lid from underneath, so that when the hatch is closed, you can’t remove this strip.
The 2x4 covers the screws which hold the handle on. No way to remove it, short of saws & drills, and lots of noise.
It takes 10 seconds to put this board in place and lock it. You’d bust your leg before you were able to boot in the companionway door open with this setup.
I guess I could have sprung for a coat of white paint on the board, but that would have doubled the cost.
In short, this is a fabulous deterrent, which is exactly what I wanted.
Dec 2, 1999
15,184
Art:
You have way to much time on your hands. Are you retired? Maybe that is why you don't have any time to yourself! <g>
Great tip!
Jun 6, 2006
6,990
Only thing I'd change is the screw heads on the forward angle iron. I'd make the angle a bit longer vertically and put the screws on the bottom so they can't just be removed with a screwdriver.
Pretty cool!
Jun 1, 2009
1,837
Hunter 49 toronto
Pretty cool!
You almost got me.
What you're looking at are the tops of nylock nuts. The bolts are counter-bored into the wood from the bottom. So, if you try and turn them, the bolts will just spin. So, you can climb down my ladder now Bill.
Apr 15, 2009
302
C&C 30 Annapolis
Sorry to tell you this but.....bolt cutter or crowbar....10 seconds max. If someone is going to break into your boat with the intent of stealing stuff, they'll come equipped. Here in Annapolis it's a yearly occurrence around boat show time. Outboard motors seem to be a favorite. If they see an inflatable on davits, they are going to assume there is an outboard down below or in a locker.
Jun 1, 2009
1,837
Hunter 49 toronto
I agree with you 100%. If it's an organized group with tools on hand, nothing short of welding your boat shut will help.
This was meant to thwart a casual attempt at entry; which I understand happens often. Guys who do illegal stuff like this are adverse to carrying any sorts of tools, because if they get stopped, or caught, they face numerous additional charges.
Basically, locks are for honest people, and it goes downhill from there
May 28, 2009
764
Hunter 376 Pensacola, FL
There was an intriguing take on this idea put forward by Captain Fatty Goodlander in one of his Cruising World columns. He found a way to tuck a length of wood underneath his seahood that makes it impossible to slide the companionway slider forward. Sort of like the old "piece of dowel in the sliding door track" idea for patio doors, except that you can't see it since it's hidden under the seahood. The cool thing about it is that if a thief cuts the visible lock, they still can't open the slider, which makes it extremely difficult to get the drop boards out, but since they can't see any obvious reason why the slider won't move, he figures they'll give up and find an easier target. Who knows, it might work.
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
I have "The Club" in my work van (Carvan). Its hot pink and stands out like a sore thumb. I even get teased on some job sites. I always park beside a van just like mine (there's a million of them).
I don't lock it. I wonder which van will be taken? The easy one.
Jul 1, 2004
567
Hunter 40 St. Petersburg
I don't know about yours
but on ours the teak piece attached to the front of the plexi is only held on with a few wood screws. I'm willing to bet that a good swift kick would be all it would take to rip the teak right off. Broken leg? Nah, I doubt it.
Having said that, as you're already aware there's really no such thing as "burglar-proofing." If they want in, they'll get in. Still, you've made it clear at a glance that your boat could be a pain to access. Most thieves are lazy. Hell, that's why they're thieves. Hopefully they'd just move on.
I've been burgled a couple times in my life and without fail the insurance company just wanted to know if there was evidence of the illegal entry (meaning I didn't leave it open and they just waltzed in.) I don't know that they would've denied the claims but at least I could show that I had at least tried to secure things.
Can't hurt right?
Jun 1, 2009
1,837
Hunter 49 toronto
You are absolutlely right
The moment you make it less than real easy for someone to rip you off, they will pick an easier target. As someone else already noted, if they were motivated, they wouldn't be jacking other peoples' stuff.
Thinking about painting my 2x4 pink
