Hi all! Good morning!
I want to share a picture as a reminder... Check your keel cable hose! The timing is pretty good to, as I know that there is a deal on a kit right now with everything you need to do a complete keel cable maintenance. Take a look at the keel cable hose I just removed and replaced. Good thing I did not mess with it while in the water!
I had to hack at the hose a little to get it removed from the metal tube, but the damage shown here is above where the turning ball lives. This damage was caused by me squeezing the hose with my hand.
Please, if you have not inspected and replaced your keel cable hose, remember it is connected to a thru-hull, and this one does not have a valve!!! This inexpensive piece of rubber is the only thing keeping your boat off of the bottom...
FYI
Phil
FYI
Phil
