Fin Keels, Wing Keels, and Polar Diagrams
To be accurate, I am referring to cruising shoal draft wing keels (like Hunter's, Beneteau's, Catalina's, etc.); not high performance wing keels like on America's Cup yachts.UPWIND PERFORMANCE: The fin keel is a more efficient hydrofoil and therefore provides better resistance to lateral motion (leeway) for a given speed. If you take a fin keel and sail it against a shoal draft wing keel on similar boats, the fin keel will point higher and faster. If you try to hold course with the fin keels, with the cruising wing keel, you lose on two counts. You don't point as high, and you don't go as fast. Note: Your compass heading may be the same, but your CMG is two or three degrees off the wind from the fin keels due to leeway. To reduce leeway, foot off. Don't follow the fin keels. Get back your speed and reduce your leeway at the same time. To find the optimum angle of attack for your boat and sail combination, you can use polar diagrams. Or you can use the "experience" approach. That is, try to catch up with the rest of the fleet by trying different combinations of course and sail trim while racing. Of course, while you are experimenting, the guys who have figured it out before the race are blowing your doors off.The construction of polar diagrams for specific boats (and sail combinations) is too complex to cover on a bulletin board. I would recommend a good textbook on the subject, Wallace Ross, SAIL POWER. It explains how to make and use polar diagrams for your boat. By the way, polar diagrams work for all points of sail, not just upwind.Good luck!
