I recently bought a 2013 Hunter e33 and would like to add a spinnaker. Does anyone have any idea what track and ring to add to the mast and how to set up the running rigging?
KG,Hi @rbrentsaunders
Congrats on the new boat! The manual for your boat is here: Link to manual On page 176 is a discussion of spinnaker launching and rigging. Illustrations on the next page.
If you are not a racer, the best option is an asymmetric spinnaker which doesn't need a pole for the clew of the sail. Makes launching and retrieving much easier. Also a "spinnaker sock" makes it even more simple. Another option would be a "Code 0" with a furling system which can be deployed for down wind sailing and removed when not used. A good sail loft can walk you through the pros and cons. Both do not need a pole or mast mounted track.
If you are a racer, you would probably already know what you wanted.
-KG
P.S. you will find lots of good documentation for your boat on the Marlow-Hunter site here: Index of /wp-content/export
Brochures, vendor manuals, as well as the manual linked above.
When you attach a tack to a tack sheet on the bow you are deploying an asymmetrical Spinnaker. When you have two sheets run a stern and a halyard hoisting the sail head to the mast head you have a regular spinnaker. In that case it helps to have a pole serve as a spar connecting the windward clew to the mast. You want the pole to lie parallel with the horizon. This is best trimmed using a line to the mast and one that runs to the deck. They serve as up haul and down haul controlling the pole positioning. The leeward clue runs to the stern. The sail is flown out in front of the boat like a kite Controlled by the sheets.Tack goes to a block attached to a hole at the top of the anchor roller.
Two different sail, both called spinnakers. I find the asymmetrical has less requirements to fly with similar but not equal performance.
