Pearson 362 Rudder
Jul 17, 2017
1
Pearson 362 Plymouth
Hello all. Looking to purchase shoal draft Pearson 362 used rudder. If anyone has one or knows where there is one I would be greatful. Have a great day Scott in Plymouth MA.
NYSail
Jan 6, 2006
3,158
Beneteau 423 Mt. Sinai, NY
Not used but did you try ruddy at dr marine..... he may have access to new one
Wesch
Dec 7, 2011
4
Pearson 36-2 Kingston, Ontario
Scott -- I have removed my P36-2 rudder. You would not want it as it has a crack along the upper leading edge and is water-logged. There will be corrosion inside, waiting to fail under load in heavy weather - worst possible outcome. Instead of rebuilding it, I have commissioned a new rudder and bearings from RudderCraft and will install this Spring 2018. I have increased the bearing wall to 1/2" using UHMWPE, reduced the rudder stock diameter to 3" and increased the stock wall thickness to 0.375" 316L stainless. The RudderCraft blade is solid HMWPE with internal water channels to encourage oxygenated water to pass over the stainless internals. Full rudder warranty for as long as I own the boat. Ash dot wesch at outlook dot com
