Hi SailSK
At end of last season I had this same problem and I fixed the broken spring. I found a spring with same diameter, same gauge of wire, and same wire rotation, but the spring was longer than the broken one. Then I guessed at a length and cut it. To match the spring ends I took my time to bend and shape the spring wire. I took my time using vice grips, slowly tapping with hammer, etc. My first attempt was a mess. But I learned and the 2nd one worked perfect. Sorry that I don't have any pictures. Maybe you have already decided to replace your Schaefer part. I just wanted to let you know that it is possible to fix if that's an option for you. Good luck to you and fair sailing come spring.
Best regards
Tony R
Sirius 21, #465, ynotsail
