John
HI guys I have a 1988 TR with a m25 xp and I would like to change from my three blade prop to a two blade prop to cut down on drag and lower rpm when motoring my PO painted the prop with a bottom paint and the copper seems to have pitted the blades. I think the blade needs to be balanced and have some chips fixed .so I thought I mite change props and keep the old one as a spear .I have seen a ss prop with wing tips bent in to increase prop surface but the CDI sounds better to me . The cost is $350 bucks and a replacement blade cost ½ $ 175 . My prop looks stuck on, the nut is painted on and I could not break it free when I changed my cutless bearing . I need a prop puller for a 1 “ shaft I have seen one for $65 dollars but it looks wimpy . any body have a link for me. John
