I have a 2 battery Guest battery charger wired directly to a breaker on my panel. The boat is currently on the hard and has good power going to it. Sometimes, when i turn the charger on, its instantly pops the breaker. That will go for a few weeks then ill try it again and it will work fine. I switched out the breaker and I am still getting the same problem. I checked all the wire connections and the only thing i found is that If i temporary remove the ground wire from the charger it stops tripping the breaker. Do I need a new charger or should i look else-ware for a problem?
