Hi Glenn,
When designing a sailboat other than a racer, how much, if any, consideration is given to the aerodynamics of the structure of the boat? For instance the deck design, cabin top, arches, gunwales, etc.
My other question is regarding bow bulbs. I've never seen that feature on a sailboat. Since it effectively increases water line length isn't there the possibility that it could improve the speed of a sailboat? Are there stability or other issues due to heeling? I know a lot of the newer designs have a vertical bow but an angled bow design could effectively keep the same waterline length (or longer). Also, couldn't it be filled with flotation or used for a bow thruster?:stirthepot:
Thanks for taking the time to answer our questions!
Manny
Manny
