To go another direction we might do as well or better with a Yeti cooler. I guess it depends on how we use the boats. But if cruising with a stop every 2 days or so, or for overnights the Yeti will keep ice ( I know this from local fisherman who shell out $400+ without blinking because they think it's a value) and frozen close to frozen.
If you consider the extra batteries needed, the charging system to match and the modifications to that old "Ice Box," the expensive cooler doesn't look so bad. I'd have to compare with ripping out the whole mess and putting a quality cooler in with a build out around it. Easy to remove and clean.
I have no relationship with Yeti. And, I think my father would climb out of his grave to give me a dressing down, if he knew I paid $400 + for a cooler.
I've noticed that several racer/cruisers come with a cooler as standard equipment.
